07-17-2016 01:17 AM - edited 03-18-2019 06:08 AM
Could you please confirm if the TCS certificate management can be done via internal Microsoft CA.
Document showing only public CA only.
Raaj
07-17-2016 11:54 AM
You can use an internal CA if TCS is used in a test environment, otherwise it's recommended that a public CA be used because authentication takes place over HTTPS.
07-18-2016 12:06 PM
Hi Patrick,
Since the TCS is always internal only accessible and it's never going to have any public access.
Can we use the internal CA with client server template.
I'm talking about the production environment and is it supported ?
Raaj
07-18-2016 12:17 PM
As long as your users are able to validate the certificate with your internal CA, it should be fine, else they'll get a certificate error and possibly won't be able to sign into the TCS website.
07-18-2016 12:30 PM
Thanks Patrick,
I will try this tomorrow and get back to you.
Appreciate your help.
Raaj
