Showing results forĀ
Search instead forĀ
Did you mean:Ā
TCS - how to check amount of downloads and views?
epicolo
Level 3
Level 3
Hi all,
does anyone know how can i check how many times a video was downloaded and/or viewed on-demand on a TCS?
When in live streaming from TCS i can check directly on Windows Media Server, but i couldnĀ“t found yet a easy way to check this after recorded.
Magnus Ohm
Unfortunately there is currently no such feature in the tcs that allows you to count views and downloads.
/Magnus
