Telepresence Conductor 8710 support
Kevin Waldon
I see that the Telepresence Conductor does not support 8710 MCU as of now but is on the roadmap.  Does anyone know when it will be supported?
Tomonori Taniguchi
TelePresence Server (8710 and 7010) is planning to support from next major release version, XC2.0 (late 2012 or early 2013).
Please note that TPS also require software upgrade releasing same time (or similar timing).
Thank you Tomonori.  We are running into capacity issues and need something to help with resources. We have immersive units as well as Tandberg/Cisco C60 and Profile units.  The immersive units always use the 8710.  Thanks again.
