Telepresence Conductor template - advanced parameters
rfrome
My conductor is running XC4.3.2
I have added the custom parameter to the Conference template to add the OnePlusN layouts,
{"callAttributes": {"displayDefaultLayoutSingleScreen": "layoutOnePlusN"}}
That seems to work fine.
I then tried to add a second parameter to add the Join/Leave meeting notifications. The TP Server release notes for version 4.4(1.20) list the parameter as:
"audioJoinNotification":"all","audioLeaveNotification":"all"
This fails when trying to save the entry.
Can someone help me with the syntax to get both of these custom parameters entered into the conference template?
rfrome
I think I have ti figured out. Hopefully this will be helpful to someone
{"audioJoinNotification":"all","audioLeaveNotification":"all","callAttributes":{"displayDefaultLayoutSingleScreen":"layoutOnePlusN"}}
I haven't tested it, but the json string you have appears correct.
