05-12-2021 01:19 AM
Hello :),
I have a very weird issue and I couldn't find a reason on CISCO websites. Maybe someone knows and can help me quickly.
Before the upgrade we were using just 7 Telepresence licenses, after the upgrade CUCM need 12 instead 7 telepresence licenses...all the devices are cisco WebEx rooms. Probably some of the devices were not recognized as Telepresence devices on the old release. I now need to know, which one and where is this change documented by CISCO.
My customer need a clarification.
Many thanks in advance,
Jonathan
Solved! Go to Solution.
05-12-2021 05:46 AM - edited 05-12-2021 06:00 AM
Webex Room devices always needed TelePresence license in CUCM. This seems to be software bug which was identified for spark devices in CUCM version 11.5 and it may be applicable to Webex Room Devices as well.
But if you are using 12 Webex Room devices then you need 12 Webex Room licenses (TelePresence license) for CUCM. The licensing is changed over the years and now you can use Cisco Webex Device Subscription to register any Cisco Webex device with CUCM version 10.x and later. Below are details about Cisco Webex Device Subscription:
You can order new licenses using A-FLEX-DEVICE part number.
05-12-2021 02:48 AM
How many webex room kit you have 12 or 7 ?
Can you share the screenshot of license usage from plm ?
05-12-2021 06:46 AM
Great, many thanks Vaijanath. My customer was affected exactly for this bugs!
Regards, Jonathan
