Telepresence table mic 60 maximum extension length
Steve Boyd
Is there published specs for how long we can extend the Table Mic 60? (CTS-MIC-TABL60)
Looks like it has a 9m cable attached, and the extension cable is also 9m - CAB-MIC-T60EXT.
My question is how many of the extension cables can we string together.   I see posts that say the Table20 mic will go 100meters, but nothing about this one.
Thanks.
Wayne DeNardi
If you need to extend it, I wouldn't be daisy-chaining multiple extension cables together.  You get extra loss at each connector.  If you some decent quality cable, you should be able to make a single extension cable which will have significantly less loss and allow you a greater distance.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
