telepresene diconnects from netwrok
mirehteshamali
Hi all , i am running  in starnge  issue with telepresence , it  disconnect  from netwrok  every now and then. please help  me out if i need to change any settings  to restore to normal. thanks
Rafal Szeremeta
Hello
You didn't provide much information here, but i would definitely checked network path,
Most likely one of the devices has flapping port.
If you run tracert instead of ping you will be able to find out which one.
Rafal
