06-16-2016 06:49 PM - edited 03-18-2019 06:02 AM
Hi team,
Please confirm if CTS-CTRL-DVC8= (Cisco TelePresence Touch Device) is compatible with TelePresence Cisco MX200 G1.
Thanks a lot.
Solved! Go to Solution.
06-16-2016 07:50 PM
Sorry, misread the Gen1 in your post. Yes, the Touch 8 works with the older Gen 1 MX200 running TC software. This is mentioned on the MX200 Data Sheet. The older hardware (MX Gen1 and C40/60/90) only support the Touch 8, and cannot be upgraded to the new CE software.
Please remember to mark helpful responses and to set your question as answered if appropriate.
06-16-2016 06:54 PM
No, the MX series will need to use the Touch 10.
See: telepresence-touch/data_sheet_c78-646041.html
Note: Any MX/DX/SX upgraded to the new CE8 software will only support a touch 10 - the Touch 8 is no longer supported with CE.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
06-16-2016 07:01 PM
Thank you Wayne.
In datasheet says that Touch 10 works with MX200 G2... Nothing about MX200 G1.
Expect for your comments.
06-16-2016 07:50 PM
