The difference between a G1 or G2 C60
Luke Sykes
Hi All
How can you tell if a C60 is a Gen 1 or Gen 2 without looking at the physical device.
Many thanks
Luke
I think the difference is just the branding. 1st Gen C60 codecs have the TANDBERG logo on the OSD on home screen and the codec have the TANDBERG logo printed infront of the codec. 2nd Gen have Cisco logo on OSD home screen and Cisco logo in the codec.
regards,
Acevirgil
Ok, Thank you for your reply
I wondered if it was in the serial number perhaps. Like how the 6000MXP went from 26A to 26B etc
Many thanks
Luke
