tms and exchange integration
onur temel
hello all,
I planned to integrate the exchange with tms instead of ctsman.
Could you help me about an integration guide and also with your advices.
Thank you.
Steve Kapinos
We have a whitepaper that helps guide you through the managing expectations and planning of such a cutover.  See the document at https://supportforums.cisco.com/docs/DOC-40301
For specifics on how to do the installation, please make sure you refer to the TMSXE and TMS installation documents.  The above material is a supplement to those and does not duplicate information in the regular installation documents.
TMSXE materials - http://www.cisco.com/c/en/us/support/conferencing/telepresence-management-suite-extensions/tsd-products-support-series-home.html
Steve Kapinos
thak you stkapino,
I will check the pdfs.
