TMS / API -> how to get overview for peripherals, touchpanel
matus.bankovic
Beginner
Beginner
Hi all,
Is there a way to generate a report  with info if the codecs are using a touchpanel or not? (TMS or API)
If yes, can there be a detail if the touchpanel is connected directly to the codec or via LAN?
Thank you,
Matus
7 Replies 7
Steve Kapinos
This information is not stored in TMS, so it's not possible to query TMS for it.
You could get most of the information if you queried the status.xml of the endpoints yourself and collated the info.
Tho I don't know if the codec will tell you if the touchpanel is remote or not.. you can get the panel details from the experimental root, but I don't see it telling you explictly if it's direct connected or not.
