TMS Booking Outlook Calendar Attachment
Patrick Sparkman
Two questions related to the TMS outlook calendar attachment:
  1. What email template does the Outlook calendar attachment get generated from, and it possible to have it be formatted same as the booking HTML email?
  2. Is it possible to send the outlook calendar attachment to people that are listed as contacts on systems added into TMS, similar to how you add email addresses into a booking on the conference information tab?
peterputt
Hi Patrick,
did you find the email template for the attachment?
Peter
There is no template, ICS attachement generation is hard-coded in TMS
OK, then the order in regards to the new Web Client URL should be adapted there...
