TMS credentials recovery
Hi guys ,
I have unfortunately forgot my credentials for the TMS . Is it possible to reset them, to the default . And if yes could someone help me with the process that i should follow ? Thanks in advance .
With Best Regards,
George
5 Replies 5
Rafal Szeremeta
Hello George
Can you access Windows box with TMS via remote desktop? Is your server part of domain?
Rafal
Hi Rafal ,
First of all thanks for the immediate response .
Yes i can access the Windows box with TMS via remote desktop and yes the server is part of my domain .Thank in advance .
BR ,
George
Great
Can you access TMS using local admin account?
Rafal
Is that feasible ? Right now i am out of the office but i will try out tomorrow . So from what i can understand you are saying that is possible to log in to TMS with the credentials ( admin) of the server , is that correct ? Thanks in advance .
BR ,
George
There are two levels of authentication when logging into TMS:
  1. Authenticating to IIS. Any local or domain account can do this.
  2. The user groups in TMS - here you can restrict what users can do once authenticated by IIS.
So yes, you should be able to log in using any account. Depending on how you have configured TMS, the local account may or may not have admin access once authenticated.
If he does not have admin access, you need to do some database magic to regain admin access. I advise opening a TAC case to get it resolved.
Kjetil
