TMS dumping data after period of time
Tim Cappel
Contributor
Contributor
I am pulling CDR reports weekly and noticed that after about 4 months back TMS doesn't show any report data.  I looked around TMS settings but couldn't find a selection where this is set.  I was curious if I am just missing it, or if this is default for TMS?  I would love to be able to pull at least a year back if possible.  Thank you
Nick Halbert-Lillyman
Collaborator
Collaborator
This is a setting in TMS (somewhere in administrator settings, I can't remember where exactly as I'm not in front of TMS at the moment).
If you are using the in-built database with TMS, it has a 4GB limit.  We had to migrate the TMS database to an external SQL server to get CDR records for more than 3 months as otherwise the internal database would grow past this size.
The purge database settings are found under "Administrator Tools > TMS Server Maintenance".
Purge Old Data in Database Tables Plan
Purge Log Plan
Recognize Your Peers
