TMS phonebook query
tpengineer
With TMS phonebooks, when we select Cisco TMS end-points rather than Manual list , it gives you 3 options ( H.323 id / E.164/ IP) , is there any method to get rid of this and get only 1 entry 1 end-point with the same Cisco TMS end-point option.
Chris Swinney
Level 5
Level 5
I asked about this problem a short while ago. We we're told that there was no way around this behavior so we raised a feature request. I would urge you to do the same, however, I doubt anything will come of it.
Chris Swinney
Level 5
Level 5
