06-18-2013 09:55 PM - edited 03-18-2019 01:19 AM
I'm using TMS 14.1.1 for schedule meeting, the booking is working properly.
But when TMS start the meeting I looked in conference control center it didn't show the active conference in MCU.
However if I call directly to MCU, it will show active in conference control center.
Anyone face this problem before please help?
Thank you
Tinnakorn
06-19-2013 12:35 AM
Hi Tinnakorn, Let us know the Java version installed and browser used details from the PC you are monitoring the CCC.
If you disable show MCU option in CCC, do you see in the active conference list ?
BR, Mahesh Adithiyha
06-19-2013 01:01 AM
Hi Mahesh,
I'm using java 6u31, Windows XP SP3.
I think it is not java problem because I can see all conference permanent room in MCU.
I also can see map and graphic in CCC.
The problem only happen only scheduled meeting not permanent room.
If I disable show MCU option it still not show the active scheduled meeting.
Thank you
Tinnakorn
06-19-2013 10:52 PM
Hi Tinnakorn, I would advice you to open TAC SR to further check this problem.
06-19-2013 11:54 PM
As you say, this isn't a Java problem. Please open an SR, and do a Wireshark between TMS and the MCU so that the TAC can look at the actual feedback we get from the bridge.
-Kjetil
06-20-2013 07:46 AM
Thank you all.
I already open TAC case.
Tinnakorn
06-21-2013 10:43 AM
Hi Tinnakorn. also appreciate your help to post with the resolution details once it is fixed in your environment.
11-10-2015 02:54 AM
Hi Tinnakorn,
What was the outcome? I have a staging environment and testing TMS (TMS 14.2.2) and can't get the Conference Control Centre to show meetings that was scheduled for the day. Definitly not a Java issue can also view the Map of all my endpoints.
Kind Regards
