TMS Smart Scheduler / Exchange Integration
Graeme Kay
Hi All,
I think this may need to be a feature request but I thought I would ask first.
Is it possible to set the email template up to be reservation only, without changing this on TMS?
The reason I ask is to avoid endpoints being pulled into a call that are not needed, if you change this to reservation only on TMS it works, but there is no option on smart scheduler to change the 'type' of meeting.
Many thanks,
GK
Only if you were able to set that as your default conference type.
The other option would be to set the default conference type to "One Button to Push" - that way if endpoints don't press the "start meeting" button, they won't join the conference, but there will still be resrouces allocated for them just in case.
Please rate and/or mark responses as appropriate.
Thanks Nick,
I figured this would be the case. I will raise a feature request to be able to choose type from Smart Scheduler.
