TMS upgrade
devraj123
Hi All,
Planning to upgrade TMS  from 14.5  to 15.3.
Can we directly upgrade ?
we are aslo planning to upgrade VCS from 8.6 to 8.8 ---can we upgrade directly?
Dev
You are correct, if someone is running TMS on the old TANDBERG hardware appliance, it only supports up to TMS 14.2, which is the last version of TMS to support Windows 2003.
9 Replies 9
Patrick Sparkman
You can do direct upgrades for both TMS and VCS, just take note of any upgrade considerations mentioned in their respective release notes.
TMS 15.3 Release Notes
VCS X8.8.2 Release Notes
Hi Patrick,
Thanks.
1-  Moving TMS from old hardware to new virtual server with new database 2012.
-will this require license migration ?
any migration document fro 14.5 to 15.3 which can outline the steps better?
Can you highlight migration steps.
Dev
No license migration needed, but you will require a release key as you're going from one major version to another, ie: 14 to 15.  Minor version changes such as 15.0 to 15.3 for example do not require release keys.
You should migrate the existing TMS database to your new SQL server, and then perform an install of TMS 15.3, during the install of TMS you'll point it to your 14.5 database and it will perform an upgrade of the database while it is installing TMS on the server.
TMS Installation and Upgrade Guide (15.3)
Thanks Patrick,
release key will be mapped to new serial number of virtulized TMS server ?
Dev
The serial number is contained within the database, so it will not change as long as you reuse your existing database.
If the old serial number is from an appliance it will require a new TMS license (and serial number). then all existing option keys will need to be migrated.
Hi Patrick,
we are not upgrading TMS. only upgrading VCS from 8.6 to 8.8
is  VCS 8.8.2 compatible with TMS 14.5.
in release note , i do not see notable interop regarding this.
Dev
It should be fine, if there were any considerations or required software versions due to incompatibility, it would be noted in the release notes and/or upgrade guides.
