TMS/VCS/TCS virtualization
Rodrigo Santin
Hi everyone,
I'm planning/thinking about to migrate my tms, vcs and vcs to a virtualized infraestructure using VMWare.
Does anyone use this kind of infraestrutura?
Edit: I intend to use only one phisical machine.
Rodrigo
Martin Koch
TMS is just a windows server with is needed for scaling external ms-sql server
so that works great for virtualization.
The recent X7 versions of the VCS-C and -E also nicely run on vmware esxi. Check out the virtual
deployment guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Virtual_Machine_Deployment_Guide_X7-2.pdf
You need special licenses for the virtualized VCS and if you had a old TMS appliance rather
than just the software. I would recomend you talk to your Cisco partner about that.
Regards the one server, you should check about your uptime demands, ...
There is no TCS virtualization by today.
Martin Koch
deployment guide:
