TMS with conductor is not integrationg
kingvoice
Hello Experts ;
                       I am getting below error while adding alias on TMS .Although alias seems to be ok . i have TMS 15.0 , CONDT X3.03 , TP 4.2
One or more aliases do not have matching conference aliases on TelePresence Conductor, or their associated service preference is not usable on TelePresence Conductor. Therefore these aliases will not be used for scheduling.
Any help would be appreciated
KV
12 Replies 12
Jaime Valencia
And have you matched the configuration from your conference aliases on TP conductor to those you configured in TMS??
java
if this helps, please rate
Yes ehen i put the alias in conductor check dialplan . it succcessfully matched with the dial-plan.
Patrick Sparkman
Can you tell us the alias you're using in Conductor, and what you're trying to configure in TMS?
Also, what settings do you have configured for Conductor within TMS, under Extended Settings?
Hello Patrick ;
              In conductor
Incoming alias (must use regex)  :  (allhands@XXX\.com).*
In TMS ;
Alias pattern :  allhands@xxx.com
Regular Expression : (allhands@XXX\.com).*
Extended settings :
10000
Unlimited
Default view Family
On
Please noted that in TMS under telepresence conductor tab
service preference: none
I just tested what you're using for the Conductor and TMS alias, and they are correct.  My TMS saved the alias and was able to recognize the service preference that the alias in Conductor is using.  Make sure that your Conductor alias is configured correct, ie: conference template, service preference, bridge pools, etc.
Thanks for your test . I have checked the alias ,etc every thing is in right place but still not working. By thw way i am using one TP server for all (adhoc,rendevous and TMS schedulling ) .
Can you provide screenshots of how your Conductor is configured, perhaps you might something configured incorrect somehwere, or I can try and replicate your configuration best I can to see where the issue is.
Thanks for the your time and help.. just refresh the services and it works.. But one question if i use one TP for adhoc , rendevo, scheduling conference . it is ok ?
Glad it's working, didn't think to have you do a force refresh on the Conductor in TMS, although when I tested your alias I didn't do that or need to.
Don't forget to mark any relevant replies as answered, to help others that might have the same issue find a solution.
I have the same problem, so what was the soloution for this in your case?
Marco
Just get it.
I forgot the Service Prefence "Pools to use for scheduling"
Now it´s working.
Marco
