08-24-2017 08:16 AM - edited 03-18-2019 01:25 PM
I have made several installtions with CUCM/TMS/TMSPE and Telepresence conductor and Telepresence server.
Now we have CMS, how does this work with TMSPE, because as I can see it doesn't.
Anyone can inform me ?
JH
08-24-2017 11:12 PM
You need to be running at least TMS15.3 to have any sort of supprot for CMS.
It's recommended though that you run at least TMS15.5 to have the best possible support for CMS available at the moment (there are still some features that don't work 100% yet though).
Please remember to mark helpful responses and to set your question as answered if appropriate.
08-25-2017 04:25 AM - edited 08-25-2017 04:26 AM
Thank you for your reply.
In my LAB I have TMS 15.5 and the latest CUCM/CMS. I just try to understand how CMS will work with TMSPE. I have made several TMS/TMSPE configurations with conductor and telepresence server. But I am not sure how TMS/TMSPE should work with CMS.
Is there some more detailed configuration manuals about this? There are several manuals on how to integrate TMS/TMSPE with CUCM and conductor, but not so much with TMS/TMSPE and CUCM/CMS
Any help/links is appreciated
Jan
08-25-2017 06:13 AM
08-27-2017 03:20 AM
Hello Patrick,
So we end up with TMSPE with AD integration, CMS with AD integration. And probably make sure everything matches between TMSPE and CMS
Shall setup a LAB environment and check it
Thank you all for your help
Jan
03-19-2019 06:33 AM
maybe you know if TMSPE is compatible with CMS ?
In spite of TMSPE EoL was already published I am thinking of configuring userfriendly TMSPE to create conferences at CMS.
Will it work ?
03-19-2019 06:49 AM - edited 03-19-2019 06:49 AM
this one means it wouldn't work ?
http://clnv.s3.amazonaws.com/2017/anz/pdf/BRKEVT-2665.pdf
(seach by No TMSPE based provisioning )
08-28-2017 03:49 PM
There is nothing in TMSPE that relates to CMS.
