TMSPE and Jabber/Movi phonebook contacts
Tom Leinos
Beginner
Beginner
Hi, how come Jabber shows findme and provisioned device in the same provisioning phonebook?
I dont know how to disable this feature. I would like the phonebook to only show one contact entry per person.
My advanced settings in provisoning phonebook looks like this:
and jabber looks like this:
br. Tom
Magnus Ohm
Hi Tom
The devices might already be imported. I would delete the source and re-create it with that advanced setting ticked off (Import provisioned devices).
Then provide access to the group you want and click the source in the phonebook and click the update button. Then go to the VCS and perform a full synchronization. This should do the trick.
/Magnus
Magnus Ohm
Hi Tom
/Magnus
Thanks for the advice, i assumed it would delete the provisioned users if i unticked the box and did a full syncrhronization.
I will go ahead and renew the provisioning source like you said.
br. Tom
