03-01-2013 06:42 AM - edited 03-18-2019 12:42 AM
Hi all,
I'm currently installing TMSXE but I get following error when I want to add an endpoint during the configuration wizard:
"Cannot connect to Exchange mailbox [endpoint]@domain.local.
The SMTP address has no mailbox associated with it... Verify that the mailbox exists and is accessible to the service user."
I followed the TMSXE installation guide from top to bottom.
I'm installing TMSXE 3.0.2 on a seperate Windows Server 2008 which is located in the same domain.
Exchange version is 2010 SP2.
The room mailbox for [endpoint]@domain.local does exist and the TMSXE service user has full access rights to it.
TMS is located in another domain though but that shouldn't be a problem I think?
Any ideas on what could be the issue here?
03-01-2013 06:56 AM
Hi Peter,
TMSXE is trying to open room mailbox with service account which you provide for Exchange connection. Please check one more time if this account has full rights to this room mailbox and name of the room mailbox in the Exchange and in the TMSXE configuration tool.
I can advice to enable this room mailbox user account in AD and try to login to this box via OWA to check access rights.
Best Regards,
Artem Borodai
03-04-2013 01:18 AM
Sorry, account seemed to be locked in AD.
Problem solved.
Thanks!
