01-08-2020 05:20 AM
Trying to make connection to codec thru LAN. Touch 10 not communication with codec. Is there any special switch configurations to make so the touch 10 will make the connection.
01-08-2020 07:11 AM
No special configuration is required on the switch. Please verify that:
01-08-2020 08:53 PM
Please also tell about which codec you are using and what is the software version of that?
Please rate if it is helpful and mark as accepted solution if applicable..
