01-17-2013 08:11 AM - edited 03-18-2019 12:27 AM
Hi all,
Any knowndates for new SW releases of TP Server and CTS-MAN.
TP Server – Next release of 3.0 = TPS 3.0 Maintenance1.
CTS-MAN – 1.9.1 version
We are waiting for fixing BUGs.
Many thanks,
Josef
01-17-2013 08:42 AM
Hi Josef,
Which bugs are you looking to see fixed in the TelePresence Server?
Luc
01-17-2013 11:55 AM
Hi Luc,
It is bug: CSCud79712 - 2.3 release is more bursty than 2.2 when talking to CTS endpoints.
Fixed-In Fixed-in: Release-Pending
Josef
01-22-2013 08:32 AM
The current plan is to release a maintenance release to 3.0 in the next month or two. However as always this is subject to change, as plans may be adjusted due to new issues arising.
01-22-2013 08:36 AM
Thank you Luc!
Any idea about CTS-MAN SW release please?
Josef
01-22-2013 01:31 PM
If we are using CTS endpoints should we hold off on upgrading to TS 3.0 until maintenance release 1? I notice that the CTS 1.9 compatibilty matrix still only lists TP Server 2.3 as compatible...
01-22-2013 10:02 PM
Nick,
More details about our issue. Maybe it can help with your decision.
We are running CTS 1.9.2 SW. We will upgrade to 1.9.3. till end of week.
After we upgrade TP Server from 2.2(1.54) to 2.3 release because of increasing number of screen licensing for free we have found there is meeting quality issue with 3screens CTS. Because of bursty traffic jitter has icreased to three time higher value instead of CTS and TP Server are located on the same segment and switch (no routing just switching).
Sound and video were not syncronized.
We have opened a TAC Case and TAC has found new BUG mentioned here. It should be fixed in mentioned release of TP Server SW.
If I were you I would test upgrade TP Server to 3.0 release and make a few test calls checking the audio/video behavior.
I think it can be done during one hour and rolback is very easy and quick - return previous SW to TP Server.
Do not hesitate to contact me directly in a case you will need more details.
Josef
01-23-2013 05:40 PM
Thanks for the info - interestingly, we had the opposite problem. We had issues when running CTS 1.9 in conjunciton with TS 2.2 - this was fixed either by upgrading TS to 2.3 or alternatively by downgrading CTS to 1.8 (this was confirmed by TAC).
We are now running CTS 1.8 and TS 2.2, but I'm hoping we can get everything on 1.9 and 3.0, although it looks like we might wait until the next maintenance release of TS 3.0.
