One solution is to create a custom program which uses TelePresence Server API; we had similar requirements and by using TPS API methods:
conference.status and participant.diagnostics and poll TPS each X seconds we were able to achieve this. A more efficient way to do it, is via feedback recievers which helps you to avoid the constant polling.
