TTC5-06 Mic Compatibility
Is the CAB-MIC20-EXT compatible with CS-CODEC-EQ- K9+?
b.winter
It's just a an extension cable. Why should i be not compatible?
It's a 4-pole 3.5mm jack extension cable, so it should work as it's just a straight through cable connecting the 4 pins at each end.
There may be internal impedance differences between that and the recommended one which could cause you issues down the track.
The "correct" part to use is the CAB-MIC-TABLE-J=
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
