TX9000 how to see my self during the conference
CN_donke.xu
Hello Friends
I had a question about TX9000,During a conference meeting can i see my self in the screen as a small pictureI(PIP),How to achieve this
Architecture is same as follows picture:
Best Regards
Donke xu
Jonathan Robb
Template wide advanced parameter configured within the template on conductor, all participants would see a self view image - in active presence (filmstrip) it will be one of the small panels:
{"callAttributes":{"displaySelfView": true}}
You may want to test this out and see if it fits what you are trying to accomplish, it may not be exactly what you want as it will affect all video endpoints in the conference.
-Jonathan
HI Jonathan Robb
I can't found {"callAttributes":{"displaySelfView": true} ,
but i found  ActivePresence Mode in Single-screen layout and Multiscreen layout
Is this a right way to solve this question?
Donke xu
copy the following line in that 'custom parameters' box at the bottom of your screen shot, check the box to enable it and save the template:
and try that out as a test.
-Jonathan
Hi  Jonathan
I had do the test,I can see my self during the conference like this:
But i found Left right upside down
In 1 small screen we can see C area
In 2 small screen we can see B area
In 3 small screen we can see A area
Is this the original design or i still need to make something change.
Donke xu
