11-30-2015 07:02 AM - edited 03-18-2019 05:15 AM
Hi Guys,
We have a cluster of two VCS clusters that have been working for a while. All of a sudden web connection to the master VCS stopped working. I can SSH into the unit and I can see fromt he event logs that its still processing calls and accepting registrations but I cant connect to the web interface.
What could be the issue please?
11-30-2015 08:44 AM
Not sure if it might be the same issue, but something similar happened to me, after a fresh install, running that particular version. It never happened to me once it was up and running. To "fix it" simply log into root, and ping something, then try to login again.
11-30-2015 08:51 AM
Thanks Jamie,
I did as you suggested but I still cant login.
