Showing results forĀ
Search instead forĀ
Did you mean:Ā
Unable to load license in VCS for MOVI
Aman Soi
Hi Team,
We are unable to load Option key for MOVI  in our VCS server.We get the error message "Failed to Add Option Key Option  Key Invalid".
The Part Code which we had orderd is LIC-MOVI-25.
regds,
aman
Yes that's correct, TMS is required for Movi/Jabber Video provisioning in addition to VCS, unless you are using a VCS Starter Pack (In which you shouldn't have purchased the LIC-MOVI-25 option in any case).
- Andreas
5 Replies 5
awinter2
Level 7
Level 7
Aman,
that option key should be going into TMS, not VCS.
- Andreas
Hi Andreas,
Thanks for reply.
This means we need to install Telepresence Management Suite first and then, we can upload option key for TMS and MOVI into TMS server.
regds,
aman
- Andreas
Hi Andreas,
Can u provide us the DOC/LINK what all TMS does along with installation guide .?
We have got VCS 7.x.
regds,
aman
For provisioning with VCS and TMS, the TMS PE deployment guide would be a good start:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmspe/install_guide/Cisco_TMSPE_Deployment_Guide_1-0.pdf
For other documentation related to TMS, you will find this at
http://www.cisco.com/en/US/partner/products/ps11338/tsd_products_support_series_home.html.
