Using Audio Science Mics with SX80
Andrey Emelin
Frequent Visitor
Frequent Visitor
Hello!
SX80 codec has 8 audio inputs for mics, but when I configure it in CCW, I can include only maximum of 2 CTS-MIC-CLNG in the order. Is this a technical limitation or is there another reason for this?
Martin Koch
Did you try to contact your Cisco sales rep for this?
I would say its a limitation in CCW and not necessary technical.
I did not check how well 8 mics work simultaneously in real life, but if I look at the specs it sounds ok:
• Eight separate acoustic echo cancellers
• Eight-port audio mixer
• Eight assignable equlaizers
