Using Video advantage with IP Communicator on CME 4.0
ciscoking6801
I am having issues getting video advantage to work with IP communicator. I am using VA 2.0.2.0 and IPC 2.0.2.0 and CME 4.0. I added the commands
voice service voip
h323
call start slow
telephony-service
service phone videoCapability 1
call-park system redirect
create cnf-files
and added the video command under the ephone. If you have any suggestions I would appreciate it.
Andrew
paal.fondevik
I had the same issue a few weeks ago, and found that VT advantage 2.0 requires at least CallManager Version 4.1(3), Service Release 1 to work with Cisco IP Communicator.
regards Paal
Paal
I am not using Call Manager. I am using Call Manager Express. There is no version 4.1 the documentation says that it should work with 4.0. that is the latest version of CME. Do you have any insight on this.
Andrew
