09-19-2012 07:19 AM - edited 03-17-2019 11:49 PM
One of our customer has got two sites consisting of cisco tandberg endpoints and vcs control and expressway, MCU.
Site A:
VCS control
VCS Expressway
MCU A
TMS
Endpoints
Site B
VCS Control
VCS Expressway
MCU B.
Endpoints.
VCS Control Clustering and expressway clustering will be done. Internet link is terminated in both the sites. I would like to know if the following are possible.
Also is it recomended to put vcs control, mcu behind firewall.
Krishna
09-19-2012 07:26 AM
Hi Krishna,
What you want to do is possible. I'd recommend that you take a look at
Can the TMS on site A reach site B?
I'd also recommend that you use TMS-PE (Provisioning Extension for TMS) if you have provisonable endpoints - Movi, e20, MX200, jabbet tablet etc.
Guy
09-19-2012 07:30 AM
Dear Guy
Thanks for your repsone. I would like to know more about the outbound and inbound call routing.
Krishna.
09-19-2012 08:27 AM
Hi Krishna,
Your deployment mostly depends on the sip domains used for Site A or Site B.
Endpoints on Site A and B will use respective sites vcs-control and expressway.
what you have to think are for the calls coming inside to the organization. are you going to use the same sip domain between same sites ?
how you will differentiate the incoming calls going to site A & B? i think probably you need to setup a neighbor zone as well between the two sites for making this call work properly.
you need to be very specific with your dial plan for the sites A & B
Thnx
Alok
09-21-2012 10:59 PM
Dear Alok,
Both Site A and SiteB uses Same sip domain. This is for a same company in two different locations within the city.
Krishna
09-22-2012 03:50 AM
Hi Krishna
i hope in this scenarion the outside calls to your domain will be resolving to site A & B public ip-address, correct? the DNS would be
if thats the case then the call could reach to any of the site and you need a neighbor zone to route the calls which are not related to site A and vice-versa for site B.
search rules will play a important role and you have to be careful with that.
Rgds,
Alok
