VCS NO RESOURCES AVAILABLE
Chet Cronin
Level 4
Level 4
I am running VCS 8.8.2 Control and Expressway.
Been working find.  99 percent of calls are H.323 calling via IP , and Alias.
Sometimes the DNS works I.e XXXX@cisco.com or XXX@tryacano.com etc.
Problem now is I only have a few Devices registered to the Control and plenty of Traversal and Non Traversal licenses.
But what happens is I keep seeing " No resources available - out of call resources "  when I try to call using the URI format .
Search History shows sometimes it hits the DNS Zone.
Example:  911003@uams.edu or   @cisco.com or @tryacano.com
Any Ideas?
I have restarted the servers multiple times.
Chet Cronin
Shashank Mahajan
Hi Chet,
We need to look into the logs on VCS-C & E to see why the calls are failing.
Could you please gather the diagnostic logs from VCS-C and VCS-E for the failed call? We would need Calling and Called URI along with the timestamp for analysis.
Shashank
Wayne DeNardi
These symptoms can be caused by poorly designed/implemented Transforms and Search Rules.   I'd start by performing some test locates on your VCSes and seeing what is happening and which rules/zones/etc are triggering for your URIs that aren't working.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
