vcs serial number via ssh
Chet Cronin
Level 4
Level 4
What is the command to get the serial number of my vcs  via ssh ???
Thank you.
Also if anyone has any ideas the vcs isn't running properly after a simple restart I tried to clear my cluster replication error.  Now it not working ???
Error:   Application failed - An unexpected software error was detected in managmentframework.pyc:
Chet Cronin
You can use:
xstatus SystemUnit hardware serialnumber
This will give you output similar to:
*s SystemUnit: /
     Hardware:
       SerialNumber: "52A12345"
*s/end
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Patrick Sparkman
If you can access the VCS, either via VMware console or SSH, you might be able to get the serial number from xStatus SystemUnit. You can also try: http://vcs_ip/status.xml
You can use:
*s SystemUnit: /
     Hardware:
*s/end
Wayne
