VCS
rahman001
                   Hi everyone,
I want to confirm if this setup below would require VCS internal and external.
thanks
ProductDescriptionQuantity
CTS-SX20-PHD4X-K9SX20 Quick Set HD, NPP, 4x PHDCam, 1 mic, remote cntrl1
PWR-CORD-UK-APwr Cord UK 1.8m Black YP-61 To YC-121
SW-S52010-TC5-K9SW Image Encrypted1
LIC-SX20-DDDual Display Option for SX201
LIC-SX20-MSMultiSite Option for SX201
CTS-QSC20-MICPerformance Microphone 201
Included: BRKT-PHD4X-MONITRBracket mounting for 4x PHDCam to monitor1
Included: CAB-2HDMI-3MHDMI to HDMI cable2
Included: CAB-HDMI-PHD4XS2Custom 4xcamera cable; HDMI, Cont. and Power (3m)1
Included: CTS-PHD1080P4XS2+PrecisionHD Camera 1080p 4x SX20 auto expand1
Included: CTS-QSC20-MIC+Performance Mic - for auto expand only1
Included: CTS-RMT-TRC5Remote Control TRC 51
Included: CTS-SX20CODEC-K9SX20 Codec - encrypted1
Included: LIC-S52010-TC-K9License Key Software Encrypted1
Included: LIC-SX20SX20 License Key1
Included: LIC-SX20-HDHigh Definition Feature for SX201
Included: LIC-SX20-NPPSX20 Natural Presenter Package (NPP) Option1
CON-ECDN-SX2PHD4XESS WITH 8X5XNBD SX20 Qk Set HD, NPP,4x PHDCam,1 mic RC1
Jens Didriksen
Level 9
Level 9
That will depend entirely on your requirements, current deployment and future needs.
If you only have this one end-point, then that would be a bit of an overkill, to put it mildly.
You can use it as a stand-alone end-point, but in that case you will only be able to use IP address dialling format for both in- and outbound calls, which in turn means configuring your firewall accordingly.
Using a VCS-C and VCS-E combination will give you secure firewall traversal, the ability to use URI dialling (both SIP and H.323) and lots more, but it's a rather expensive solution and not something I would even contemplate if I only had a couple of end-points.
In this case a better soluton would be a VCS-E starter pack, see
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11305/ps11315/ps11337/data_sheet_c78-697075.html
for details.
But, again, it all depends on your requirements, current deployment - and budget.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Tomonori Taniguchi
SX20 support both standard H.323 and SIP as call protocol.
You may register SX20 by using H.323 or/and SIP and utilize feature on VCS (such as firewall traversal call, alia lookup, call management, CPL, etc.).
If you have single SX20 (or several SX20) just calling each other by IP address (assume have routing capability on each site), then you can directly all each other by IP address base dialing without VCS.
However if you have SX20 in local network (or in home network behind home gateway), should deploy with VCS Expressway to avoid extra firewall management and reduce security concerning as VCS Expressway will provide firewall traversal capability for SX20 (SX20 does support ASEENT/H.460.18 traversal protocol for H.323 and planning to support ICE for future software release).
