08-24-2011 08:18 PM - edited 03-17-2019 10:27 PM
I would like an analogue device to receive a busy tone when the far end terminates the call?
I currently have an intercom with a PLAR which the intercom does not hang up because it is not receiving a busy tone when the far end hangs up the call.
I'm running a VG224 with CUCM 8.5(1)SU2 in SCCP mode.
Heath
08-25-2011 12:46 AM
hi Heath,
what's the full call flow ?
can you provide the output of debug vpm signal ?
Karthik
08-25-2011 03:31 PM
The call flow is PLAR enabled Analogue Device > VG224 > CUCM > ARC Console
When the operator disconnects the Analogue device stays off hook and don't want it to redial.
Using document http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbasic_ps10592_TSD_Products_Configuration_Guide_Chapter.html
I have performed a no dial tone remote on hook and added tone busy remote on hook on the related dial-peer with no joy
I will get the debug and will also try the voltage denial with supervisory disconnect.
08-25-2011 05:35 PM
Hi heath,
ok so if the port stays offhook after the operator disconnects then
you can try enabling "no battery" under the voice port that the system is
plugged into.
There is also a supervisory disconnect which can be enabled. Basically it's
a powerdenial system that kicks in when the call ends.
"supervisory disconnect lcfo"
You can try this one also under that voice port.
Make sure you shut/no shut the port after you enter the command.
Karthik
08-25-2011 11:02 PM
That still had no luck.
Just wished the following command gave back the busy tone with remote on hook as the doco states.
dial-peer voice 223 pots
no tone dialtone remote-onhook
tone busytone remote-onhook
service stcapp
fax rate disable
port 2/23
I will just manually re-configure the intercoms to dial the extension opposed to using a PLAR.
Heath
