Video calls between VT Advantage and Polycom
Jesse Zepeda
Level 5
Level 5
I have a customer that is running CM 4.1 w/ VT Advantage clients. They want to connect to a partner that is running a Polycom Video Conf. endpoint. We currently have a PRI going into the 6608 blade of the 6500. The Polycom supports Video over IP. What do I need in order to get this to work. I'm guessing maybe a 35xx gateway?
Steven Smith
Level 7
Level 7
ipvc 3540 or 3526 will do it for you. You can get a 3540 with pri cards, a mcu and an emp. Or you can get the 3526 that will do the pri, but is not expandible.
http://www.cisco.com/en/US/partner/products/hw/video/ps1870/prod_models_home.html
Hope that helps.
Steven
