10-19-2007 02:57 AM - edited 03-17-2019 09:09 PM
Hi Guys,
I am currently trying to configure 2 3825's to act as both gateway and gatekeeper so I can proxy video conferencing between two locations. I have applied what is seemingly the correct configuration to my interface to enable h323 gateway functionality, I have also configured my local and remote gatekeeper statements and prefix's.
However I can make calls between endpoints within the same zone(gatekeeper) but remote calls fail.
If I do a show gateway It would appear my gateway is not registering with the local gatekeeper(i.e itself)
Any Ideas???
edited conf below;
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address x.x.0.83 255.255.255.248
no ip route-cache cef
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
media-type rj45
h323-gateway voip interface
h323-gateway voip id gk-re-uk.ja.net ipaddr x.x.0.83 1718
h323-gateway voip h323-id gk-re-uk
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 194.81.0.83
gatekeeper
zone local gk-re-uk.ja.net ja.net x.x.0.83
zone remote gatekeeper.some.ac.uk some.ac.uk x.x.14.130 1719
zone prefix gatekeeper.some.ac.uk 0011*
zone prefix gk-re-uk.ja.net 0022* gw-priority 10 gk-re-uk
gw-type-prefix 1#* default-technology
lrq forward-queries
no shutdown
10-25-2007 06:23 AM
Check the gateway for: The gateway command is enabled:
gw(config)#gateway
At least one dial-peer voice
10-30-2007 06:43 AM
Are you invoking any IPIPGW/Session Border Controller/CUBE resources for external call legs?
