Video Conferencing over IP
Nkechi Latunji
My customer has cucm8.x, cups 8.x and Unity 8.x in a centralized call processing with 5 remote sites in total connected via MPLS. They are interested in a video conferencing solution for boardroom and desktop.
What cisco solution (hardware and software) should I be looking at to satisfy this need. I need to make a presentation tomorrow, assistance is much appreciated. In the board room they would like to use their LCD TV as well for picture display or any other alternative. Not telepresence, too pricy for their requirement
Nki
William Bell
Well, you may not care any more since you have presented you may have already presented your solution....
Anyway, Cisco TelePresence no longer refers to the high-end "immersive telepresence" product line. Cisco has decided that TelePresence is a brand not a product. This brand now includes hardware and software that have been absorbed in the Cisco portfolio as a result of the Tandberg acquisition.
So, don't let the term TelePresence in a Cisco doc throw you off.
Cisco has plenty of video options in their portfolio now, go here:
http://www.cisco.com/en/US/partner/products/ps7060/products.html
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
HTH.
Bill
OK. I had a look, so many options and not enough time to research all of it before getting back to this customer. Based on the customer existing environment Centralized call processing with CUCM8.x, CUPS8.x and Unity 8.x what telephony products can I put together to satisfy mulit party video conferencing between desktop and Board room users?
Customer has been pressing for a solution and I am under the gun to have something presented.
Nki
Arun Kumar
Hi Nki,
As William said, try Cisco Tandberg Solution, that will be a really good fit for your requirement/s. If you need any further help let me know.
Arun
Nkechi Latunji
Thank you. I will check out the link. Customer is eager to get this going
