VIDEO-CONFERENCING SOLUTION
smmashal
Hello Dears
We have one main office and 7 regional offices and we want to connect all of them through  video conferencing solution . all the offices has connectivity to internet and there is no VPN or any other kind of connectivity with our main office. we need a solution that enable us to have multiparty (upto 7 ) video conference .please provide me your recommendation that is suitable in term of cost and performance for our requirements
thanks in advance
George Sotiropoulos
You may try Cisco Webex Teams, you may check the link below:
https://www.webex.com/products/teams/index.html
You better contact a local Cisco Partner though to listen to your needs and drive you to the most appropriate solution.
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Wayne DeNardi
Your best option is to talk to one of your local Cisco Partners (you can find them using the Cisco Partner Locator tool).
They will be able to help you design a solution that fits your needs and budget.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
