Wall mount for 7912 IP Phone
chadthompson
We currently use the 7912 series IP phones and are looking for a way to mount them vertically. We have purchased a locking wall mount (http://www.cisco.com/en/US/products/hw/phones/ps379/prod_installation_guide09186a00800a8689.html) that is supposed to work with all 7900 series phones. However, it using mounting pin holes to mount to a phone and these pins holes do not exist on the 7912 model phone. Please explain how this mount is supposed to be installed to the 7912 phone.
tbramwe
Level 3
Level 3
Chad:
Here's the universal wall mount kit install guide.
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_installation_guide09186a00801d0356.html
It has the 7902, 7905, 7912 models shown.
Tom
tbramwe
Level 3
Level 3
Chad:
Tom
Rob Huffman
Hi Chad,
Just to add a note to Tom's good post, I am pretty sure that the 7912 uses a different Wall mount kit. Have a look at the different part numbers;
7905,7912
CP-LCKNGWALLMNT2=
7940,7960
CP-LCKNGWALLMOUNT=
You probably ended up with the Wall Mount Kit shown in the attached doc;
Hope this helps!
Rob
Please remember to rate helpful posts.....
