Webex Desk Pro - If I use a USB-C to USB-A adaptor does Camera/Audio
natalie.bennett
I want to use the Webex Desk Pro's camera/audio for a desktop video call.
If I use a USB-C to USB-A adaptor, will this work?  I have to be sure the camera can be used as the video system I am using is totally web-based.
I would also be using an HDMI cable to duplicate my laptop screen to the Desk Pro, and the Touch Redirect.
Ammar Saood
Hi Natalie,
Yes, you can use WebEx desk pro as a USB Camera, Microphone, and Speakers with any SW client using USB pass thru feature.
Laptop/PC must be connected via either a USB-C-USB-C or a USB-C-USB-A cable. You can also connect a USB C hub.
Moreover, using USB ports on the back or lower right side of your Desk Pro, you can connect a USB mouse and/or keyboard to your Desk Pro, and use them for your laptop.
Hope this helps,
Please rate & click "accept as solution" if this answered your Question.
Use either USB-C  or HDMI  to connect to your laptop.
  • USB-C for extension of display, touch redirect, laptop charging, and access to camera and audio control.
  • HDMI if you only need an extension to your laptop display.
For Desk pro, Touch Redirect also works if you only use a USB-C cable
If I use a USB-C to USB-A adaptor, will this work, better to conduct a POC.
Response Signature
