01-29-2022 07:56 AM
which one from red highlighted can i uploaded into cucm and upgrade webex pro from it
Solved! Go to Solution.
01-29-2022 11:00 AM
The first one is used for CM and the other can be used to upgrade from the webUI.
01-29-2022 05:11 PM
Newer COP and ISO's are sha 512 singed. Before installing SH512 signed COP, If your current running version is lower than the number in the table, you will need to install the ciscocm.enable-sha512sum-2021-signing-key-v1.0.cop.sgn COP file in order to enable sha512 support.
01-29-2022 09:18 AM
cmterm-ce10_8_2_5.k3.cop.sgn, Both release notes mentioned the same set of devices.
Read the release notes.
01-29-2022 09:31 AM - edited 01-29-2022 09:44 AM
So what about the other two cop files, are the being used to upgrade the kit by it's GUI?
01-29-2022 09:40 AM
Other two is sha512.
01-29-2022 10:04 AM
I didn't get you, where we can use those?
01-29-2022 05:11 PM
01-29-2022 11:00 AM
