3rd party DX80 VESA mount kit
dacarmon
Hi Team, anyone aware of a 3rd party VESA adapter?  Thanks
JFerello
The DX80 does not have a VESA pattern on the back of it.  You HAVE to buy this adapter from Cisco to give the DX80 a VESA pattern.
CP-DX80-VESA=
VESA Compatible Wall Mount Kit for DX80
Justin Ferello
VESA is an industries standard, https://vesa.org.
Check the hole pattern the DX80 use and find a mounting option that fits your needs.
Response Signature
JFerello
CP-DX80-VESA=
Justin Ferello
Thank you for the replies.   For what I understand the DX80 needs a Cisco plate to mount on a VESA adapter.  The VESA adapter can be 3rd party.
I just mounted two DX80 with the VESA adapter and it is not parallel to the wall. Instead the bottom is sticking out about 2 inches more than the top.  I see the bottom part of the wall mount does not fully touch the DX80, but this distance will probably still not be enough for proper display.
Anyone have this issue?
