9971 not working
abukuru95
Participant
Participant
Hello Guys, i have a 9971 phone but i cannot
get the camera to work. all parameters seem fine. i activated it in system ->enterprise configuration ->cisco camera enabled.
any advice to get this working?
thanks in advance
4 REPLIES 4
Anton Nechay
Beginner
Beginner
did You turn camera on at 9971 device menu settings?
yes
Arun Kumar
Check the below link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/8_5/english/admin_guide/9971cam.html
and make sure you are using supported version of CUCM otherwise you are running into a known bug CSCtf17163
check the bug details to fix this issue.
Arun
the problem is now solved.
it was a power nogotiation problem between phone and switch.
thanks
