05-19-2011 07:02 AM - edited 03-17-2019 10:18 PM
Hello Guys, i have a 9971 phone but i cannot
get the camera to work. all parameters seem fine. i activated it in system ->enterprise configuration ->cisco camera enabled.
any advice to get this working?
thanks in advance
05-19-2011 11:39 PM
did You turn camera on at 9971 device menu settings?
05-19-2011 11:41 PM
yes
05-25-2011 04:04 AM
Check the below link:
and make sure you are using supported version of CUCM otherwise you are running into a known bug CSCtf17163
check the bug details to fix this issue.
Arun
05-25-2011 04:31 AM
the problem is now solved.
it was a power nogotiation problem between phone and switch.
thanks
