03-09-2018 04:23 AM - edited 03-18-2019 01:57 PM
we have sx10 device and shows in the screen not activated and asks for activation code
what kind of activation code it asks from me?
please help me?
Thsnks
regrades
Hasan Nisar
Solved! Go to Solution.
03-09-2018 06:23 AM
Hasan,
The activation code is a code generated from your Spark Admin Portal. If you are not using the Spark cloud service, then you can bypass this. You may need to factory reset the SX10 to be able to bypass the screen again.
03-09-2018 06:23 AM
Hasan,
03-09-2018 09:19 AM
can they do video conferences with outside SX10 without the activation code?
03-09-2018 04:58 PM
03-09-2018 11:21 PM
how to register in CUCM/VCS or spark?
03-15-2018 10:53 PM
To register to CUCM, you need an available TelePresence Room License in CUCM so it can register, to configure the CUCM and the SX10, see Administering TelePresence Endpoints on CUCM.
To register to VCS, see the Configure H.323 and SIP section of the SX Series Getting Start Guide.
To register to Spark, see How Do I Add an Endpoint in the Cisco Spark Control Hub.
02-07-2019 01:14 AM
02-07-2019 02:04 AM - edited 02-07-2019 02:07 AM
Hi Nay,
Edit: This has been already explained in the above thread.
This activation code you require only if you are registering your Spark device with WebEx cloud. you can generate by following instruction mentioned in the collaboration help page. Generate an activation code for your device.
if you are registering on-premises solution you can bypass this by performing a factory reset.
As per the screenshot, your device finds difficult to contact the cloud. so please check with your network/firewall team if they are not blocking the connectivity from your spark device to the cloud.
Shalid
Please remember to rate helpful responses and identify helpful or correct answers.
02-07-2019 05:14 PM
02-07-2019 05:24 PM
