TelePresence and Video Infrastructure
Does anyone have the cisco powerpoint describing setting up the passthru options for the webex room kit plus, kit pro ?  I believe one option was using the vaddio a/v bridge.   Looking for cisco's recommendations for setting up passthru ..  Thanks
EnvironmentRoom KitRoomOS 11.15.1.6Registered to WebexTouch 10After installing the RoomOS 11.15.1.6 update, my Touch 10 was unable to boot to the home screen, getting stuck at the Cisco logo screen and rebooting constantly. It did not have this issue...
Main issue:  The Webex Room Kit Mini is pulling an IP address, but the TelePresence Touch unit, which is connected to the Room Kit's dedicated Touch port (which I assume acts at least as a pass-through network port) is not (it's getting a 169.254.x.x...
TSinAK by Level 1
  • 2395 Views
  • 10 replies
Hello, reading the datasheet and admin guides of a Roomkit EQ lead us to interpret that it cames with HDMI audio out, but after some tests our technician found that the audio is not working on HDMI outputs, only the embedded QuadCam speakers provides...
Elter by Level 4
  • 115 Views
  • 1 replies
