08-15-2011 12:36 PM - edited 03-17-2019 10:25 PM
Does anyone know of a way to set how long a Movi client will dial another user (before abandoning the call) if the other user is not answering the call (but is online)? In my testing, the dialing just continues to ring perpetually.
Solved! Go to Solution.
08-19-2011 02:38 PM
Hi Andrew!
I have not seen any provisioning parameter, sounds like a feature request on the client site.
But it should be possible to do some magic with a CPL or FindME to add some generic call
failure / forward after some time.
Martin
08-19-2011 02:38 PM
Hi Andrew!
Martin
08-19-2011 06:13 PM
Hi Martin,
Thanks for the feedback. Our Cisco partner provided a similar answer that it can be done with FindMe, which we have yet to deploy. I may consider submitting a feature request as well.
